break in...
05GlastronSX
i just bought a 2005 glastron sx 170 with a 150 merc xr6, and i was wondering how long is the average break in period for an outboard engine like this? i was told 2 hours but thought that was a little on the short side. i know i have to mix oil in with the first tank of gas, and that i have to vary throttle speeds while not letting it idle too long nor any extended periods of WOT. also, is there a recommended time that i should take the engine in to get its first "check up" or service done before winter? thanks
RatFish
Re: break in...
The engine owners manual will address the proper break-in procedure and duration.
roscoe
Re: break in...
Geez, where'd you buy this, M W Marine?<br /><br />Any other dealer would have made sure you had all the breakin instructions in detail.<br /><br />Check the owners manual.<br />Didn't get one? Contact Mercury and get one. Also inform them of the poor treatment by their dealer.
thepr1nter
Re: break in...
I just bought a Sea Ray with 3.0 L Mercruiser and according to the manual, for 20 hours you should run the engine no less than 1500 RPM for extended periods and no more than 3/4 throttle. Also they recommend not going from idle to full throttle until after 20 hours are on the engine.
Richard Petersen
Re: break in...
I treat boat engines like a car engine, which they are. 1 hour of 2000 to 4000. Then hit as you like. All my Nissan cars go +125000 and no repairs. Lets see if my GM 5L is as good.
moderator1
Re: break in...
XR6 is an outboard guys...break-in procedure varies greatly with manufacturer too.<br />Common sense would say "Get a manual" and possibly "Ask the dealer that sold it to you".
kozman01
Re: break in...
ALot of people follow the theory that the "break-in" period is put into the manual by the manufacture to protect them from liability in case an inexperienced operator is at the helm. They tell you to take it easy on the engine because it needs to be broken in when in all reality, they don't want you running across the lake at 50mph not knowing what your doing. Personally, I fall in between these two thoughts. On my motorcyles, it gets alot of heat cycles and engine braking for approximately 100-200 miles to seat the rings, but never any redlining. Change the oil at 20 miles and 200 miles and the engines are good to go and you can run them like you want to. I take the same satand with my boat motor. Run it reasonable w/o any WOT for the first 1-4 hours. Change the oil out and then run it like you want. The only problem that I believe can occur is and I'm not sure what newer engines have this, but if you boat motor has any type of diagnostic test device on it, it may have a memory of what is going on with the engine and if something fails in the motor, and they see that on the 5th hour of the motor, you ran WOT, it may give the manufacture a leg to stand on if they want to deny your warranty claim because you didn't follow break-in procedure. Now, if the engine doesn't record you activity and you say have a major failure, there is no way for them to determine that you ran 4300 rpms as opposed to not exceeding 4000 rpm for the first 20 hours or whatever. If something fails, it's not because of not following a "break-in" procedure. It's because the manufacture didn't produce something correctly or put it together correctly. I'm sure many people will not agree with me and that's fine. that's why I take the middle ground on the break-in procedure. The only thing I do know is that I've seen quite a few bike motors that were broken in gingerly and their motors were not up to par. The thing is, ALL motors, no matter what application they ar used in, were stress tested to redline or WOT at the factory. Just take it easy on her for a few hours and then run her like a reasonable person would. Just change that oil early, there is alot of metel shavings coming off that new motor, get rid of them early. Finally, I'm not advocating not folowing your break-in procedure. I'm just stating my opinion of WHY there is a break-in period.
scubatrooper
Re: break in...
My Mercury manual states for the first 10 hours try not to idle too long below 1500 rpm, let engine heat up to normal operating temperature, vary rpm range but avoid WOT. After 10 hours through 20 hours vary rpm range, okay to go WOT for no more than a few minutes at a time.<br /><br />Steve
