John Reynolds
- Joined
- Mar 18, 2003
- 212
I have a mercury factory service manual, model C -- 9 0 -- 2550. About Breaker points, it says: "a Breaker point dwell setting of 48 degrees is recommended for Mark 58 and later model four-cylinder engines. Mark 55 and earlier model four-cylinder engines use a 54 degree Breaker point dwell setting. For optimum performance these recommendations must be followed." The book also says: "Set breaker point gap to .008 inches for an approximate setting of 48 degrees dwell." Since the book says Mark 55 and earlier, and I have a Mark 55, then my engine must use the 54 degree breaker point setting. But my question is, if a breaker point gap of .008 inches gives a dwell 48 degrees then what do I need to set my breaker points at an order to achieve a 54 degree breaker point setting? I can't find anywhere in the book that will tell me that.
