Re: Breaker Points retrofit
I have to agree with Tashadaddy here. Power Packs do fail, and usually become intermittant before they quit altogether, causing untold grief. I have over 27 seasons with a 1975 9.9 Johhny that uses points. If you use a meter, or test light , you can set the points quite accurately, and more importantly, get them both the same.
I must caution you however to use a good quality condensor made in USA, old stock is fine. Newer Taiwanese made condensors have a habit of failing, we have seen this in Go Karts, Motorcycles, and Outboards when replacing condensors.
The reason I like points in these engines is because they are Magneto type, and do not use 6 or 12 volt DC battery current. This means the current through the points is lower and they tend to last quite a long time as compared to automotive style battery powered points. Additionally, I have never had a problem with miy ignition on the 1975 9.9hp, but I have replaced numerous 1980s power packs...what does that tell you?
