Re: Breaking Crankcase apart
Got advices for you ,but first, I do not know your engine ,so don´t blame me .<br /><br />If you are planing to do some work on this engine , you shuld get yourself a manual .<br /><br />Are you shure you have removed ALL bolts ?<br /><br />The powerhead are removed from the rest ?<br />Have you removed the carburators + intake + reeds , maybe some bolts under there .<br />You got all the mainbearing bolts , shuld be 6 bolts ( 2 on top, 2 senter ,2 lower )<br />You also have some dowel pins ?(2 or more)they will only go out one way ( to the crankcase side ??)<br />You have removed ALL bolts around the crankcase flange .<br />If you are shure that ALL bolt are removed ,try knocking on the crankcase with a plastic/rubber hammer , do NOT use force .<br />If nothing happens ,look for more advice
<br /><br />Do not remove all bolts around top/lower bearings , shuld be 6-8 under + 6-8 on top (maybe more)leave some of them i place ( those on the sylinder side ) until you have removed the "crankcase" half of the block ( they will hold the crankshaft in place when removing the connecting rods ).<br /><br />DO correct me if I am wrong and/or missing something
