steviecops
- Joined
- Oct 3, 2003
- 585
Hi<br />I took my boat out for the first time since fitting the new powerhead. (Johnson 50, 2 cylinder). I had started the boat in a water butt at home previously, and let it idle for about 30-45 minutes total. Yesterday was the first time it has been out on the water.<br /><br />I did a search for the recommended rpms for break in, but found that I couldn't apply them to my boat and motor. I didn't want to put the motor under strain, so I gave it enough throttle to get up on the plane, then backed the revs down to where it would just stay planing. That gave me around 4000 rpm cruising, anything less and the boat would start dragging through the water. <br /><br />I found that when I gave full throttle to get the boat up quickly, I could only get 5000 rpm. Previously I'd get 5800 at WOT once the boat was planing. Would the double oil make the motor sluggish? Or could it be that the new powerhead needs to loosen up before I'll get full rpms? I know that I've still got many hours breaking in to do yet, and I should not try to hurry the process, but I was worried I might need to set the motor up again before taking it out for the second time. A friend of mine who knows about 2 stroke motor bike engines was out with me and said he thinks it is the extra iol and "tight" engine that is making me lose rpms. He says that when I run it on 50:1 again, it'll rev higher. Is he correct?<br /><br />I set the timing using the cranking speed method. Set at 15 degrees instead of 19. Jets in carbs are fixed orifice jets. Carbs were cleaned out and rebuilt with new kits. New Champion plugs gapped at 40.<br /><br />Any advice would be appreciated.<br />Thanks<br />Steve
