breather cailing oil?
mbueker
i have oil on the front of my 99 50hp coming out of carbs the vro has been plugged and mixing oil with gas. am i mixing to strong?
Silvertip
Re: breather cailing oil?
If you are mixing at a ratio of one pint of oil to six gallons of fuel its the right mix. But even an incorrect mix should not "oil up" the front of the engine. Bad reeds perhaps allowing excessive spit-back. Float levels set too high or needle and seat not sealing causing fuel to dribble out the carb making you think its oil?
mbueker
thanks i will look at carbs i also have a high idle problem that i can not solve may be in carbs thanks
