Re: British Seagull project
Wonderful engines.Metal impeller.Spark plug should be a champion D16 if it's a forty plus engine-serial number will begin with FP if it is. Serial number is stamped into a flat on the crankcase. The only engine I've ever had that uses marine grease in the lower unit instead of oil-and no oil seals.Designed to be maintained with 3 tools- a hammer, an adjustable spanner and a screwdriver.There's thousands of them, still in daily use over here.<br /><br />As for restoring the appearance, I don't think they ever looked new
<br /><br />They run on 10:1 premix by the way-and when you use it make sure you take at least 2 spare drive springs and split pins with you-as soon as you touch down on the bottom they break.
