Broke plug wire
jlw1972
97 Johnson 115 xflow
I managed to pull a plug wire out of it's boot. I stuck it back in so I could make it back to the dock. Do I need to replace this wire or will it be ok to run it like this??
boobie
Re: Broke plug wire
Are you talking about the boot that goes on the spark plug ??
boobie
Re: Broke plug wire
You should be able to fix that. Cut the plug wire off 1/2", bear the inner core and put the spring terminal back on with a pliers. Then put some WD-40 in the boot and slide it back on.
emdsapmgr
Re: Broke plug wire
Follow boobie's suggestion. If you purchase a replacement coil wire from Bombardier, it comes as a kit and you have to put it together. You should be able to re-assemble your current coil wire and have it function properly.
jlw1972
Re: Broke plug wire
It was just like you said it was. I fixed it.
