Broken anti-cavitation plate fix
n2ostroker
So this weekend the lake was dirty. I was out cruising Friday night and ran through some crap. A small log must have got into the prop and broke the anti-cavitation plate on one side.
Where can I find a replacement? Weld on or otherwise.
It's an Alpha 1 Gen 1 outdrive.
ganoleman
Re: Broken anti-cavitation plate fix
I have the same problem. Vibrates on turns and lost power on startup (suspect it's cavitating). I was looking at those plates (i.e. Hydrofoil) that bolt on to the lower end to get up on the plane quicker as a less expdnsive fix - not sure if they work though - looking for ideas that don;t hit my bank account to hard.
Gary H NC
If its a large piece missing it may cause turbulence around the prop.
As far as a fix...a new lower gear case.
Careful welding on it as the seals do not like heat..
n2ostroker
My drive is so deep it doesn't hurt the way it drives. Played all weekend and never noticed a difference. But I am wanting to sell the boat next yr so I do want to fix it. Welding isn't a problem I just need to know if they make a piece to weld back on. It's a fairly large chunk (7-8" back on one half).
