Jack Daniels
- Joined
- Sep 21, 2007
- 266
Have a quick question, last season when tailoring home, i didnt have the transom saver on tight enough. As a result, the motor bounced a little bit and broke off the bolt that holds the bracket that allows you to tilt the motor all the way up and lock it into place. The bracket is still ok but the bolt is broken completely off. So my question is, is this something that can be removed with a broken bolt remover, was the original bolt welded to the mid-leg, can i drill and re-tap, or should i just take it to a machine shop to have them fix it. Its really doesn't harm the operation of the boat, it just makes it a pain in the butt to launch and load. Thanks for the help.
