Re: Broken Bolt on trim cylinder - how to replace?
I sheered the head of this bolt and I need to know a good way to get this bolt out of there
I'm glad your story ended well. I recently dealt with the same thing on a 1994 trim cylinder. As mentioned, removing the other bolt and anode gave something to grip. I also used small Vice-Grips (original brand, which have "grippier" jaws than the cheap knock-offs) for twisting the bolt. I also soaked the bolt overnight with Kroil before using much force. The main additions I want to add to this thread is:
a) use enough squeeze on the bolt to avoid slippage
b) start gentle and add more force gradually
c) wiggle the wrench back and forth, not just torque in the "undo" direction.
I like to use lots of (c) and more penetrant oil after I get the smallest movement from the bolt, gradually transitioning to more and more "unwind". In the particular case here, the broken bolt backed out easily once it had broken free of the aluminum corrosion locking it to the cap.
On the other hand, the worst outcome isn't the end of the world as it is not too dear to simply remove the cap from the cylinder assembly and replace it with a fresh one.
