broken bracket please take a look 73/65/evinrude
sandspike
url]
Can someone tell me how to get the side that is broken off. thanks
Hotrods
Re: broken bracket please take a look 73/65/evinrude
Remove the {IMG] in your text, hit picture and past just the url. Pic is small looks like the transon bracket right?
sandspike
yes it is the transon bracket. i have no idea how it happened but just want to get it fixed.
jimmbo
Remove the motor from the boat and it will be easier to understand how the bracket is put together. Looks like impact damage.
Evinrude Boater
Yes jimmbo's right. You're going to have to remove the whole motor to get the bracket off to either replace it or try welding it. It's a pain but you want to make sure it's done right. You don't want to go Johnson fishing later.
jimmbo
If the motor goes overboard when the other side breaks consider yoursekf lucky. That sucker will still attached to the boat by the control cables, the electrical harness and fuel line. More offen than not it trashs around and leaps into the boat, not a good thing seeing a prop at WOT in your boat. Get it fixed.
sandspike
thanks guys. getting it welded this week.
