Broken/Cracked remote filter mount - temp fix?
stouchton
Looking for some critique on a temp fix for my remote oil filter mount, 4.3GXI-E. I must have cracked it 2 years ago when I installed new risers/manifolds. I am planning on replacing it, but it is not easy - the bolts cannot be withdrawn since there is no clearance between deck and riser. I will need to completely disassemble riser to remove bolts (I have to lay it on its side). I am fine doing this the end of the season, over the winter. Right now I just want to run it.
I am thinking of JB-Welding the oil filter mount back to its ears, and securing it with a large hose clamp to the riser. Basically just the ears have broken free from the mount, and I figured I just want to keep it from moving around to prevent flexing of the hoses (and springing a subsequent leak). The hose clamp alone could do that, but thought the JB-Weld would just help keep it from moving around.
Does anyone see a flaw in this plan just to get me thru this boating season? I do have a new mount on order. I could also possibly locate some holes thru the deck above the riser to withdraw the bolts. I have a rope/AC power box on the transom right above the risers that could hide the holes - I would patch them of course.
Thanks in advance for any feedback - just wanted to make sure I was not overlooking anything obvious.
cptbill
I used JB weld on my windless on the Larson about 4 years ago and it's still holding, it's like the 5200 of 2 part epoxies
Ayuh,..... I'd skip the JB weld, 'n clamp it up,.....
stouchton
Thanks guys for the feedback. I'll be strapping it to the riser and running it till fall. Not sure how I ever overlooked the fact that I cracked it.
