I am trying to remove the port side head on a 1975 115HP because the spark plug thread has stripped in No 4. I have removed all bols except for No.2 (the middle inner bolt see photo). The head of the bolt snapped off so if I can get the head off I should be able to use stilsons to get the bolt out. Both pistons are down and I can rotate the head slightly by tapping with a hammer an block of wood. Looks like corrosion between the bolt and head. I am soking penetraiting fluid, but there is no obvious leavering point to get the head off. Do I have to apply heat to the head and then tap it?
Any help appreciated.
Thanks
Richard
Thanks
Richard
