Broken magnets
Roberthill
1976 25hp Mercury serial #5842749
Outer magnets busted in flywheel,question can these be replaced ,if so where can they be purchased at? Or should I look for a used flywheel?
A 1976 model 25 HP ??------Any pictures of this motor ?----Part # of the flywheel ?-----Google that part # and see if one is available on E-BAY.
Roberthill
I found a couple on e-bay. Part #258-859232T15 . Seems a waste not having magnets available. Don’t have pictures. Thanks for your help.1645140719951.jpeg
Flywheel in the picture does not look like the flywheel off a 1976 model.----Do not believe there was a 25 HP in 76.-----Should be easy to find a flywheel.
Roberthill
Flywheel in the picture does not look like the flywheel off a 1976 model.----Do not believe there was a 25 HP in 76.-----Should be easy to find a flywheel. Yes Mercury has a 25hp 1976 . That picture is for a 1976 25hp.
Obviously I know very little about motors and years they were made.----- I will step aside now.-----But show me where a 1976 model 25 HP is listed !!!
Roberthill
My son brought this motor over for me to look at , he told me it was a 1976 and I found a listing for a 25hp using the serial number , but you have got me thinking that he got the wrong year , will check into this in the morning .
merc850
No 25hp in 1976 the small motors go 4.0-4.5-7.5-9.8(110)-20-40 hp.
It shows up in 1980 along with an 18, new to the lineup.
dwco5051
25 2 1467499 1962
25 2 5705532 1980-81
25 2 5942041 1982
25 2 6185159 1983
25 2 6453343 1984
25 2 6593849 1985
25 2 A911346 1986
25 2 B114231 1987
25 2 B238464 1988
25 2 B385500 1989
25 2 C221500 1990
Roberthill
Most who know would instantly recognize that to be a 1981/ 82 model.----The 76 model 20 HP motor is totally different with different unique decals for 1976 models !!
flyingscott
That flywheel is extremely common just buy one and go boating. That will be neither a Marathon or a Sea Pro.
Roberthill
Got one on order , suppose to be here Saturday. Probably going to have more issues, lot of neglect on this motor.
Roberthill
25hp Mercury serial #5842747 (1980/81 I think)
Don’t know where to start . Flywheel magnets are cracked , but I was told shouldn’t hurt , I do have another one on order. Right now there is no spark to plugs. Is there anything that I can do or should I wait on flywheel replacement?
Do a complete evaluation of this motor before spending your beer tokens.------On those models 9 out of 10 have needed a new water pump impeller.----At least on my work bench.----Compression test first !
