Broken screw - '68 Johnson 40hp Sea Horse
sds357
Just got back from the water and while inspecting the outboard I noticed that the small cover plate on the lower unit for the water intake was bent back because the front screw broke that was holding it on. Anyway I used a easy out to try and extract the screw and of course it broke inside the screw. now i cant drill it out since the easy out is too hard to drill. I need some suggestions on a way to keep the cover in place.<br /><br />Thanks<br />sds
roscoe
Re: Broken screw - '68 Johnson 40hp Sea Horse
A small amount of JBWeld should hold it in place.<br />Not too muck, just a dab, so you can knock it out with a chisel if you ever have to take it off.
