Broken shifting mechanism - Lonestar
80skeys
1971 Lonestar 16' aluminum.
In the front of the boat near the steering wheel is a box that contains two levers: the gear shift and the throttle. The gear shift mechanism broke inside this box. The broken piece is a white plastic piece - it sits on the cable and holds the lever arm to the cable. It broke in two, resulting in one piece resting on the left side of the arm and another piece on the right side.
I'd like to know the recommended way to fix this. Should I attempt to locate a replacement for the piece that broke? Or is there some sort of "generic" replacement for the entire lever box?
80skeys
QC
Re: Broken shifting mechanism - Lonestar
Don't know about replacement parts, but here is a complete setup. I am guessing yours is the same manufacturer as your motor . . . ;)
80skeys
Thanks a bunch for the link.
But wow, at $120, I can hardly justify it considering that's more than 1/5 what I paid for the boat + motor + trailer.
I'm hoping for a $10 solution on this one!
QC
They're common on eBay etc. Good luck!
tmcalavy
If you want much help, you need to post make/model of your outboard and control box...guessing it's an OMC/Evinrude/Johnson? As already said, best bet is to watch Fleabay for an entire replacement.
80skeys
The outboard is an 1964 Evinrude 28hp. Model 28402M. There's nothing written on the control box.
tmcalavy
Okay...fyi to help you find a replacement: Evinrude motors came with Evinrude Simplex shifter/control boxes. Johnson motors came with Shipmaster boxes. They are identical except for the name. Get on Fleabay and search for OMC dual lever control box or OMC two lever control box...OMC was parent company of Evinrude/Johnson.
