Broken skeg on an Alpha One drive
ggundersen3
I'm looking at a '99 19' Maxum with a MerCruiser 4.3L Alpha One drive. The skeg is broke. Whats the best way to fix that? Is there an after market skeg that can be mounted somehow? Does a replacement have to be weld on? Is it OK to operate the boat without one? See photos
Ayuh,...... No Problem,.......
There are bolt-on, 'n epoxy on replacements, though that one maybe to short for a bolt-on,......
The proper fix is to pull the lower unit, 'n weld on a new one,.....
Bt Doctur
Have to agree ,a bit short, a new replacement lower is about 600
Rick Stephens
I would weld a new one on. Clean it up, fab fit a replacement. Pack on the heat block to keep the gearbox coolish. Any propeller shop can do it fast. I have a welding shop and would have no issue, but I've also spent some time wrenching on drives so know what the risks are to the seals if I let them get hot. A good welding shop can do this in a short period of time if they understand and handle properly the risks.
You can run it that way. No problem.... except touching down with your prop. That skeg keeps the prop from dragging, in the wet or on the trailer. Get it fixed as soon as you can. Weld on!
achris
More fish than mountain goat
Merc sell a weld on replacement. You have a Gen II (I see the anode on the bearing carrier), so the part number is -90185A1
Should cost you about $80...
Chris.....
Rick Stephens
Take the dash off his number (90185A1) if you go looking for it at any of the Merc parts dealers. I tried to search at iBoats and all I get is Forbidden error page. Search is broken.
Last one I fixed I just fabbed up the skeg from aircraft alum. Wasn't hard.
andrewterri
With how smooth that is it looks like someone might have forgotten to raise the drive when pulling out of the water.
