Broken timing pointer...swap intake manifold or make one?
guitman32
The timing pointer on the intake manifold for my donor powerhead was broken...
I have the old intake manifold, with the timing pointer still attached...but Id rather avoid swapping if I can...
I can also fab my own pointer, I suppose...But can I accurately ascertain TDC without a TDC tool as prescribed in the manual???
And a final question...could one set a conservative max advance while on the water? Or is this just altogether a bad idea??
Haffiman
Re: Broken timing pointer...swap intake manifold or make one?
You may in principle make a timing pointer anywhere you like, it may just not align with the timing marks on the flywheel.
The TDC stopper is not a necessity to determine the TDC, you may use a bolt, caliper, dial gauge or whatever to measure it out.
guitman32
Thanks for the quick response haffiman....
So I just measure TDC, and make sure my homemade pointer is pointing to 0 on the flywheel, correct?
