Broken transducer cable
acc
'Bought this boat out of a guy's barn....Depthfinder was working but IMHO marginal...'Finally found a spot where the transducer cable has been broken then an attempt to repair it had been made......<br /><br />I want to repair it correctly....<br /><br />Any experience on this subject???<br /><br />Any suggestions....<br /><br />TIA<br /><br />curtis
cpasseno03
Re: Broken transducer cable
What I usually do is to solder the inner strand. Then strip back the outer insulator farthest, followed by the sheilding, followed by the inner insulator. tape up the inner solder joint. Then pull the shielding together(leave yourself enough) and solder them. wrap this one with some tin foil just to be sure, then cover it all in some tape.<br />always worked for me...<br />Craig
acc
Thanks, Craig....<br /><br />Your suggestion is basically what I did.....but found another break up close to the transducer........<br /><br />'Patched it as best I could....After supper, I'll run down and dunk it in the river for a quick test...In the meantime.....ebay......
rverano
Make sure you use a good quality electrical tape like 3m Scotch 33. Cheap electrical tape will not last long in the water. A little silicone on the final connection before the taping works to keep the water out as well.
acc
'Went to the river and checked the dang thing out.....no success.....the cable break at the transducer was just not physically repairable.....<br /><br />I did assure that power was getting to the transducer.....stick your tongue to the center conductor and it shocks the **** out of you....<br /><br />I found an old Humminbird transducer, cut cables to match the length, and attached it....I can now hear the Humminbird click so maybe I have a fix...<br /><br />In the meantime, I'll search for a real replacement....<br /><br />Next question......Is any Lowrance transducer with a grey connector a replacement????<br /><br />Thanks....
buttonhook
check bass pro shop they sell replacement cables.
duck-n-pond
By the looks of my transducer cable, it looks like a co-axial cable. This means that the cable is designed to have certain sheilding and impedance characteristics. Any change to the physical dimensions, such as a kink, squat, or overtightened ty-rap can effect its performance. I would only try to repair when in dire straights in the field. Replace the cable. Also, moisture inside the cable can corrode it inside the sheath, and of course, you will only find out about it when you need it most!
acc
Latest and Last report on this subject.<br /><br />I spliced in an old Humminbird transducer....I soldered the center conductors then put some hot melt glue around it...Then I spliced the outer conductor and soldered it....then taped the whole mess.........<br /><br />'It finds the bottom satisfactorily.....But I'm still not happy.....It could be the patch job or it could be the old Humminbird transducer.....<br /><br />Now seeking a replacement transducer but I have something to suffice until I get one....
acc
OK, this is really the last post from me on this topic.....<br /><br />I received the replacement transducer and installed it last nite....Went out this AM and tested.....Works fine....I'm pleased with the performance....<br /><br />BTW: Got the unit from Three Rivers Marine - a reputable supplier located somewhere in PA....Price was good....shipment was prompt....
tdowns57
to repair tranducer cable get apoxie kit 5min dry also go to electronic supply house get small heat-srinck that just slide on the center wire then the same on the outside cable.with the heat srink on the center cable sorder center cable. mix the apoxie apply over the sordered connection slide the srink over the connection take your iron heat the scrink untill the apoxie comes out each end.repeat on the out cable make the scrink about 1/2 inch longer on each end of the repard area.this will not allow any water into repared cable.
