New 454 Big Block with just about 45 hours on it, thru hull exhaust. This new engine was installed after freeze damage from the original motor.
Was running at about 50mph last year with the new engine when the alarm went off and simultaneously the engine shut down completely, this happened about 1 mile after a 30 minute no wake zone. I tell this becasue the boat was running in the water without stopping for atleast and hour before it shut-off
I Got towed in etc. Checked the dipstick, the oil level was very high and smelled of gas.
Returned the boat and engine back to the marine shop. They pulled the engine, the first mechanic said I must have sucked something in, fried the impeller and the engine overheated. Second mechanic said we need to pull the exhaust and possibly heads and see what happened.
Pull the exhaust off, looked with a flashlight into cylinder 8, the head of the valve was broken off from the stem and the stem banged-up the top of the piston. The spark plug head was completely sheared off.
Couple days go by and I was curious about the impeller so I returned to the marine shop and I pulled the raw water pump and lines. I found-a bunch of pieces of broken impeller in the pump housing and in the water line. The actual impeller itself was in perfect condition. The impeller chunks I found must have been left in the line from the old engine and when the mechanic installed the new engine, he never flushed out the lines.
Anyway some more time passes.
The mechanic calls me and said he discovered water that got in the engine from the exhaust and it was the water that caused the valve to break. He discovered that one of the gates on my right exhaust tip that is meant to prevent wake water from backing into the engine was missing, he advised that there was allot more water in the right side were the gate was missing and the right side was the side with the failing cylinder 8
(So)
Mechanic: Is blaming water through exhaust as the cause of the valve failure
Me/I: Believe the engine overheated from the cooling lines being obstructed with impeller chunks and the overheating caused the valve to fail.
Finally getting to the actual question.
1st-------------Is it even possible for water through the exhaust to create valve damage like this as the mechanic is saying???
2nd-----------------If the mechanic is right and water got in through the exhaust causing valve failure, what are the signs to look for????
3rd-----------------If I?m right and the engine overheating caused the valve failure, what are the signs to look for????
(So)
