Re: Bruce anchor vs. fluke anchors
I keep both on board, the bruce hanging on the bow and the fluke stowed in the engine compartment. First thing is that you need to use chain to take full advantage of each type of anchor. I have a 24' cruiser and I use 20' of chain. That chain will save your anchor line from abrasions but most importantly allow your anchor shaft to stay parallel next to the sea bed.
That said, the bruce is really easy to set but in sand or mud it will plow and furrow in strong winds or walk down wind as the boat sways back and forth. Bruce anchors will reset them themselves real easy but each time they do it will walk a little bit. Bruce anchors do much better in rocky, gravel and weeds then do fluke. I use the bruce as my primary anchor because of its easy to set. If it is windy, 15 knts or more then I use my fluke anchor.
Fluke are awesome on sandy or muddy bottoms. With chain and a 7:1 scope they will hold tight in high winds. I personally like the Fortress fluke because you can change the angle to 45? which perfect for mud. I use this as my storm anchor.
