toplesshorse
- Joined
- Oct 12, 2007
- 11
I have a 1976 85 hp Johnson. I just installed a 135 hp bubble back exhaust plate. There is a fitting in the bottom of the new plate that was not on the old one. I plugged it. Is this going to be a problem? Doesn't the water exit the same way it did on the old one out the ports below the power head? Do I need to put in the fitting and drill a hole for a tube in the bottom of the engine housing plate? I plan on running it in the drive way with the water hook up to test. Make sure no leaks.
By the way if anyone wants to try this you will need monkey hand like my son and a short 1/4" drive extention in order to reach the lower three bolts. Be patient and have a magnet on a stick ready. You will drop the center bolt a few dozen times. Also, go with 1/4-20 x 1 1/2" bolts grade 5.
