BUCCANEER Aluminum Boat?
satx78247
Friends,
I have found a 14 foot aluminum "open fisherman", which sides back by the stern read BUCCANEER III. - After trying several internet search engines, I find ZILCH on this boat.
(The current owner thinks that the hull is a 1958 model. The OB is a 1958 twelve HP GALE 12D17B and it's on a 1958 Dilly trailer.)
Does anyone know anything about this boat?
THANKS.
yours, satx
jbcurt00
Re: BUCCANEER Aluminum Boat?
The 1958 Crestliner Buccaneer 15 was available as an 'open' Model 601:
which is the middle graphic w/a 40" bow cover.
Maybe?
satx78247
jbcurt00,
Well the 601 sort of looks like the Buccaneer III, except that the little fisherman is a foot shorter, considerably narrower in the beam & different in the stern, so I just don't know.
(Of course, most "tin open fishermen" look SIMILAR.)
Also, I would be stunned if the 14ft was rated for more than 20-25HP.
I wonder if the Crestliner Buccaneer had a "little brother"???
THANKS for your answer.
yours, satx
jbcurt00
Yep, a few:
It was the best I could come up w..
satx78247
I thank you for trying anyway. I wonder if this hull is a "knock-off" of some major maker's boat?????
(As you know, there are MANY "splashes" of fiberglass runabouts & utilities. - Like REDFISH was usually a "knock-off" of GLASTRON.)
OR
An example of some "little regional builder" that didn't last long, like my HURRICANE PLASTICS of Houston, TX utility that went TU in about 7 months.
(I have a "laundry list" of well over 50 "Texas Small & Independent Boat-builders". - I would be stunned if more than one other person here has ever heard of PLEASANT BOATWORKS, as they made TWO runabouts before closing forever in 1956.)
yours, satx
satx78247
To ALL,
Right now I'm trying (so far, with LITTLE success!) to buy the SOLE remaining runabout made by Pleasant Boatworks.
(The other boat was "chain-sawed" & "hauled off" about 2 decades ago.)
yours, satx
