Re: Buffer
Makita makes a nice 7" sander/ polisher - others do as well but the 7" size is what you need. RPM's should be a two speed affair - low speed at 2000 rpm's and high speed at 3800 rpm's. Always use the slower setting when buffing.
The pads I use are 3M foam. White for oxidation removal # 05723 and the black one's for finishing # 051131. The backing pad is also a 3M product
# 05717 or 18 ( pretty much the same thing ).
Go buy a couple of 2-1/2 or 3 inch chip brushes and use them to apply your buffing material on the hull. Smear it around good with your pad and go at it. If you just apply it to the pad it will sling your polish everywhere.
Oh, a supply of adult beverages is also recommended !
