Re: Buffing an old oxidized glastron.
Hold off on the idea of respraying, that's a last resort type option.
Get a buffer, it needs to turn about 2500 RPM or less, Harbor Freight has them for a very low price.
For the best results find a supply house that carries a line of buffing compounds with several grits, start with coarse and work to the fine grit product. Try this first, if you don't get the results you desire use a fine grit paper 800, 1000 or 1200, always use the finest paper you can and sand it lightly, then use the compounds again. You may also have an option on the buffing pads, fast cut, polishing, etc.
Try all of this in a small area first to see what works best for you.
This boat looks far to nice to mess up on, or take a path of no return like spraying with clear coat.
