Re: Build a floor for my 12' V-Hull
I would love to have a floor as well, however, weight is a factor so I will have to pass on this.
I too have a 1972 12' seaking, great little boat, light. Mine is rated for 550lbs max.
I'm 6'2", 250lbs, outboard(7.5) 50 lbs, tank with fuel 50lbs. add fishing gear gear, anchor, oars and I have about 150lbs to play with.
That pretty much leaves any of my friends fishing from shore.
I have run this boat 60lbs over the rating and it really changes the handling, it plows alot of water, its slow and not efficient, slows to half speed in tight turns and will actually allow the wake to hit the corner of the stern. It would be very easy to take on water.
So please consider the heft of what ever you are using the boat for.
