My current boat 268 searay weekender needs more power.When fully loaded up with gear,people and fuel she probably weighs close to 7500 to 8000lbs. Needless to say with a single stock 260 hp engine it's under powered.So my choices are either build up a 350 or install a big block. Would rather just build up a 350.What type of cam and pistons should i use? The boat is a 1986 350 4bbl carb.Already got the stuff to convert over to vortec heads. I have a newer style block that can use either a reg or roller camshaft.
