Folks,<br /><br />I am getting ready to put my rebuild together (mechanical components, tank, engine, fittings, etc.)<br /><br />After reading comments on this forum and details in my Clymer manual, certain adjustments (like timing) need to be done under power. I would like to build a test tank that I can run the motor at WOT.<br /><br />Given the above I was contenplating a tank that is roughly 6' x 4' x 2'(deep). Does anyone have a recommendation for the size and shape of the tank so I can run the motor safely. My intention is to be able to lower the motor into the tank (back up to the test tank and use the T&T) while it is bolted to the transom.<br /><br />The motor is a Johnson 82' 140hp.<br /><br />Any and all help is greatly appreciated.<br /><br />Safe boating to all.<br /><br />Cheers.<br /><br />emp.
