I'm re-doing an aluminum '91 SeaNymph 171cc...Removed flooring, foam and stripped bare & clean. Boat has an underdeck aluminum fuel tank, not used by previous owner...he used portable plastic fuel tanks because he felt it was easier for re-fueling. I removed the tank to check it...How do I clean the inside and check it to make sure it's ok to use? It seems in good shape w/ minimal pitting. I'd like to use it to free up deck space and to keep weight lower and more forward.<br />Or, is there any benefit to using the portable plastic tanks? Any problems to be aware of w/ aluminum tanks?<br />Thanks, beached
