Built in Fuel Tank
SS MAYFLOAT
The two boats that I own have built in tanks. They are aluminum, one is a 44 gal. and the other is 100 gal. The plywood decking above them is sound and strong, but when you walk over them, you tend to bounce up and down somewhat. Is this typical for below deck tanks? Since I have two boats that do the same thing, I thought it was common, but thought I would post this to see if it is a concern.
hellbender
Re: Built in Fuel Tank
S~ SS,<br /> ive built afew boats and tinkered with others but have never have heard of that...you didnt say how old the decks are.even with marine-wood coated in resin still doesnt last long from what ive seen.the deck couldve popped from the ribs and when wet swell but im just taking pop shots here.you could find your ribs and try nailing them back.gl with the fix.my fishing time is spent now cutting out the deck&ribs in my 73 13'glastron.not fun but a must for a lighter,faster,&farther,and setting a tank in the floor for more gallons.
SS MAYFLOAT
On my 67 Stingray V-20, it is the one with the 44 gallon tank. The tank is about 4 feet long and 3 foot wide. The plywood that covers that area is just a tad bigger. It then is anchored to vertical supports that come up from the stringers, (they are structuraly sound). It was replaced several years ago because of the spongy feeling. After replacement, it was still that way. I thought it was because of the span that it covered. Example would be like having your floor trusses in your house set on 4 foot centers.<br />Then the 100 gallon tank in my CCruiser is the same way. That tank is 4 feet wide and 6 feet long. The space between the floor and the tank is about an inch an a half. There are not any ribs that span across the top of the tank. One suggestion was to put foam between the tank and the floor, but to me it is a NO NO to use the tank for support.<br />Thought about having 4 pieces of stainless bent into anle to bridge the span, but however that gives me clearance problems between the tank and supports for it to be effective.<br />What happens iside my cabin is this. My table is a pedestal style and the pedestal is mounted on the plywood that is above the tank. So when someone steps into the cabin, their weight transfers to the floor inside, my table will then drastically move an inch or two. Enough to spill anything that is on the table. And then it moves each time a step is taken. I know this is typical in some cheap trailer campers where the floor is not supported adequately.<br /><br />I did think about taking out the tank, install three smaller ones and then put in some vertical supports off of the stringers. But thats alot of money just to fix a shakey table. Thanks
