I have an 88 model 178 and discovered the floor was soft under the 3rd or middle seat base. I have some boat building and fiberglass experience but things change so much I wanted to try to find some advice from folks more up to date before I dig(literally) into this. My guess is to remove the carpet ad identify the problem, which I believe to be localized to the area around the seat base and not much more. Had the transom replaced and some of the gel coat tightened up a couple of years back by a pro and while it was apart he and I tapped around the whole boat and could find nothing wrong, so this is a surprise to me. When I replace this I will not be re-installing the base that caused the problem in the first place. After ID, cut the problem out leaving the edges a 45* angle, leaaving a ledge to support the fix. Treat all exposed wood with resin and let cure, I'm not sure if it is necessary to add cloth under the floor and then install the wood, maybe in a thinned bondo like material to eliminate any voids, or to just dope up the edges of the wood and glass over it with increasing patch sizes. I sure don't want to fool with this again.. The boat is in great shape for it's age as it was a garage queen when I bought it in '09 with original carpet and interior and no oxidation on the gel coat. It will serve me well for years to come as long as I can afford to feed the 150 mariner on the back. Thanks in advance for the response, Y'all have always stepped up to the plate when I needed you most........Tim
