Bunch of suzuki questions
gotboostedvr6
The engine is a 87
1. How can you setup an omc prop for a DT 75? will it need washers?
2. How much water pressure is needed to properly cool this motor? 15psi? less?
3. Is the lower unit gear ratio 2:1 ?
4. What is the safe max rpm i should run in a performance app? they will be short runs of not more than 1 min.
5. OMC motors will run with no controls attached, will this Suzuki?
6. Any performance suggestions are needed and appreciated... :)
JUSTINTIME
Re: Bunch of suzuki questions
ask brownspoint.com
at least 10 psi
ask brownspoint.com
ask brownspoint.com for rpm range
yes
