Hi,
I have a trailer that is 41" wide frame to frame. What I want to do is install bunks that will give it a wider base so I can just drive my boat right onto the trailer. Currently I'm unable to do that because the bunks currently on it aren't far enough apart.
So I'm thinking if I can attach bunks to the outside edges of the frames it will give me a wide enough base. The difficulty I'm having is finding bunk brackets that will angle away from the center of the trailer. I want to extend the 41" wide base using bunks to 52". At 52" the bunks should just hang slightly over the wheel wells by about 3" on each side.
My trailer does not have any cross bars going from one side of the trailer to the other. Is there anything out there that I can use to achieve what I'm looking for? Thanks.
