Bunk rollers
GBJMACK
Has anyone ever replaced their bunks with these bunk rollers from Amazon?
Welcome
I'm sure they will work "IF" they can handle the weight and can be placed correctly to support the hull
What boat/trailer would they be used on? Have pics?
If they are about the same length as the original then I don't see a problem
airshot
I prefer to use the wobble roller units as they fit/ support the hull better. On aluminum boats you can't have to many rollers. To few and it will dent the hull.
JimS123
I replaced the OEM bunks with this very setup a week after I bought my brand new Starcraft / Load Rite setup. Worked perfect.
Add up the boat, engine and stuff total weight and then divide by the number of rollers. If you have less than 100# per roller you will be fine no matter what type of hull.
GBJMACK
That's awesome. I need something simple to replace the bunks as I launch my boat in some shallow places. Thanks
