BUNK SLICKS WOW! just FRIGGEN WOW!!!!!
smokeonthewater
Since I started using the Monte Carlo I have been power loading it..... I KNOW I shouldn't be and I have tried to use as much inertia as possible but it has always taken LOTS of throttle for half a second to get it to the bow roller.... I couldn't winch it on (I have a big winch and I tried) and I couldn't back in any deeper without dropping off the ramp.... I was doing a bad thing and I knew it.... what can I say... guilty!
So I have known about the virtue of bunk slicks and have steered many people toward them but I never actually used them myself..... I have intended to add them to my trailer but I haven't had the money to get them.... I figured I needed a LOT of them to do the over 40 feet of bunks on my trailer and that was gonna be pricey..... Well today I was looking at the 8x10" piece of 3/4" teflon I had left over from making a spacer for the windlass and at the 3/4" gap between the hull and the front of my center bunks..... I ripped it into two 4x10" pieces and drilled 4 countersunk holes in each...... I launched the Monte Carlo and left it running, tied to the dock. I pulled the trailer up and zipped in 8 screws, backed it back in and loaded..... I idled on and gave it a SMALL blip of throttle just before it stopped moving..... WHAM! it hit the winch stand hard enough to worry me until I looked to verify nothing was damaged.... whole new ballgame...
I KNEW these things were good but I'm blow away.... two little chunks of plastic under a boat that is 33' oal and nearly 10,000 lbs.... I didn't know they were THAT good!
No longer will I be messing up the ramp. I'd say that now I can launch and load shallower and I can likely winch it up the last bit now.... :cool:
KDAVID1
Re: BUNK SLICKS WOW! just FRIGGEN WOW!!!!!
That is very cool--it will take a bit of time to get used to the ease now--congrats to you
smokeonthewater
thanks..... yeah I will never again have a bunk trailer without slicks..... It loads easier than my full roller did on my last boat
sschefer
My dad tried them on a 14' tinny thinking it would be easier but the boat was so light in the first place it didn't help at all. Not sure what he was thinking. I had them on my 18' and they were just like you say, better than rollers. My current boat (Jetcraft) launches in 18" of water and pushes off with one hand on carpeted bunks I also have no problem cranking it on after I skid up far enough to step off onto the trailer (notice how I avoided the term power load... LOL). I thought about putting them on but decided I really don't need them.
Your call on using using the bulk material for skids is right on.. Much cheaper if you buy it in bulk at Tap Plastic's. I also highly recommend them to anyone that's having problems getting the boat on or off the trailer.
jigngrub
uhhhh, you own that big of a boat and couldn't afford bunk slicks?
Keep and eye on your screws... countersunk thru bolts and nyloc nuts would probably be a better choice.
Fireman431
An alternative to teflon or bunk slicks is a can of spray silicone on carpeted bunks. You would not believe how slick they make the bunks.
Philster
Yeah, be careful with the screws. Even countersunk, they work themselves out. They have a rough life. I like the countersunk bolt suggestion. I might try that.
I, too, can't believe just the small pieces are needed. I love mine and I usually just float on, but there is one ramp where powerloading is the only option without a crane!
smokeonthewater
that's right....
I used what was on hand... I'm satisfied with it for now. As easy as the boat slid on they CAN'T be seeing all that much sheer force. I DO agree that there are better hardware options if I went shopping 'stead of using what I already had.
Yeah this ramp is STEEP but it just isn't an issue anymore :D
26aftcab454
I did the Silicon Spray on my carpeted bunks and it is "Slicker Than Snott!"
I use shallow ramps and do not want my pick up's brakes & rear end submerged.
dpoff
You might want to radius the exposed egdes of the teflon blocks to make the hull happier. Just a thought.
DaNinja
Spent the day yesterday with the Starcraft on the hoist. I could tell how much harder it was to clean and polish the lines where the bunks were. Would these strips be better, or worse in that regard?
smokeonthewater
they already were... this teflon came from a slaughterhouse that was torn out.... It was a counter top so I put the front edge of the counter to the back of the trailer
