Buoyancy Foam
FluffyChicken
Re: Buoyancy Foam
I like that idea. But doesnt pour in place foam add more strength to the whole structure?
sdunt
Re: Buoyancy Foam
Some boats were and are designed for the foam to be an integral part of the the structural strength. In my case there wasn't any foam in there to start with. Also the pieces I installed are cut to fit tightly and actually bear on the inside of the hull was well as the back of the floor.
There is also PL construction glue holding the foam in place to the hull and floor.
But the foam installation will also drain because its not adhered to the hull and this foam just will not soak up water.
And, you won't find pour able foam for these prices..
mtnrat
Re: Buoyancy Foam
Interesting solution for foam. I am also in construction and I have dug up the type of foam you used from below the water table and it definitely had not absorbed water. Hmmm.
FluffyChicken
Re: Buoyancy Foam
whats PL consturction glue and can i get it at homdepot or lowes?
sdunt
sdunt
Re: Buoyancy Foam
Is it equally as buoyant as the pourable foam?
OK, I'll give you this lesson for free. :)
Water weights 62 LBS per cubic foot, so every Cubic foot of water you displace is 62 pounds of 'buoyancy' you do have to subtract from that 62 Pound figure the weight of your foam. The pourable foam that is called 2 pound, weights 2 pounds per cubic foot..
A 4 by 8 sheet of 2 inch thick foamular is 5.3 cubic feet. and I can't find a spec on weight, but a sheet of it can not weigh more than 5 pounds if that..
SO yes, it is equally or more buoyant than pourable, because by the time the boat is old enough to be swamped the builders foam is still DRY and will support 60 pounds / cubic foot vs pourable that will be 25 to 50% wet, and thus support less.
If you like to read: http://www.shortypen.com/boats/oday19/float/index.htm
FluffyChicken
Re: Buoyancy Foam
Wow that guys experiment said that the pourable stuff sucked up the water like a spunge. now that i think of it. when i was pulling out the old foam form the boat towards the bottom there was a ton of saturation. i never really put 2 and 2 together. Thanks guys.
So as long as I cut the pieces so the fit snug and use that PL stuff it should add a lot of rigidity to my boat?
