Crankstomp
- Joined
- Apr 1, 2004
- 28
Motor is a 1977 175 Evinrude model#175749S. I purchased it a few months ago with very little knowledge of it's history. Last weekend I was running across the lake at full throttle, engine slowed down, I backed off the throttle and it started knocking/rattling so I shut it off and cruised in on the trolling motor. I pulled the plugs and the #6 plug had aluminum on it. I suspected something bad, so I did a compression check(previously 115-125 on all cylinders) all checked out good except #6 cylinder. It was only about 20 psi. Pulled the head and the top of the piston was melted off and deposited on the intake side of the piston. There is some scoring, I'm guessing a few thousanths, to the clyinder walls. All the other cylinders look fine(well sort of, more on that later). I have two questions. First, what are the most likely causes of the melted piston? Is it because of running too lean? Also the engine was previously rebuilt with oversized pistons. My service manual says the piston to cylinder clearance should be .0055 to .0075 but mine is huge(just eyeballing I'd say .015 to .02), but the cylinders look good. You can still see the crosshatch from honing.. Can the pistons be this worn out with very little wear on the cylinder? Also, can the pistons be this worn out and still have 125psi compression? Sorry about writing an entire encyclopedia. Any advise is appreciated.
