Busted helm
heaty1
Yep, I turned the steering wheel so hard on my boat I busted the helm. The motor '84 Evenrude 150hp was stuck (in center position)I could not turn it because it had sat to long 3 1/2 mos. It spent 15 yrs at the beach so the motor will stick after sitting for awhile. My question is... It look's fairly easy to do but is it? It's a 1984 19ft Arrow Glass center console all the fitting's for the cables ect... are in good shape there is little to no rust on the boat, nut's, bolt's ect.. If I have to replace the cables are thay a beast to work with? If I disconect the cables from the motor do I need to keep an eye on anything? If I buy new set up will it hook up and steer straight? If anybody could help me on this THANKS!!! Good day to all.
ODDD1
Re: Busted helm
Jeese, heaty......you got anything left in yer fleet runnin? you should get a job at the marina just for the break onparts costs......LOL
12Footer
Re: Busted helm
Disconnect the cable at the helm and turn the<br />motor manually back and forth whilst observing the diconnected end. Is it moving?<br />You can pick up a new helm for 46-80 bukz,and use the old cable. Check local marinas for a good used set (cable and helm).<br />They aren't too hard to pull,but you need the proper tools.<br />A good wheel puller<br />diagonal cutters (for tie-wraps)<br />A drill (if the screw flange is rivetted on)<br />Socket set<br />They are not complicated, but when replacing it, take your old cable with you,or measure it.Because they come in different lengths.<br />Helm gearing is another concern. They come in different steering ratios, like 4:1 ,2:1 ,or direct. (4:1= 4turns of the wheel to full-over motor).<br />hope this helps ya.<br />I'm no expert, but I DID sleep at a Holiday Inn last night
<br /> <br /><br />------------------<br />I came, I saw, I Have No CLUE!
heaty1
Re: Busted helm
That is a good queston oddd1 and the answer is YES! I've got 2 (used to have 3) 1 is worthy of any conditions... That would be my jon boat. I just bought a new 5hp Honda 4 stroke tiller for it and it does fab for what it is. So you got a good motor and a boat that dont leak you got a good ching... Look out for the buey's!!! Wow, the Holiday Inn thats awesome! 12footer you the man! Thanks for the info Hollywood (12footer) I've got everything except for the wheel puller whatever that is? I'll find out when I ask for it at the parts store... Thanks again 12footer for the answer to my question I'll have my sweety (center consule) out be for you can say Jimmaknee Crickett.
