Re: Buying 1st boat. Need tips
I plan on buying my first boat off of craigslist in a couple months. My price range is about $1500, i plan on getting a 14ft jon boat with a 9.9 or higher engine. Now my questions: What are some good used engines that should looking for on the boats? What are the true differences off V-hull and flat hull jon boats? Any advice can help.
It would help very much if we knew your location.
In general, a jon boat is a good choice for small bodies of water and for rivers. They are stable and have a shallow draft. The disadvantage to john boats is they have low freeboard and they do handle wind/waves very well, including boat wakes caused by heavy traffic. Because of the low freeboard and the square nose, you have to be very careful in handling the boat where there are waves. One poorly approached wave will swamp out most 14 foot john boats, I've seen it happen and plucked the unlucky occupants out of the water.
In general, I think a v-hull is a more versatile setup. It can take on more waves and wind, and it only gives up a little as far as shallow water running. Becuase a v-hull has more freeboard, IMO they don't give up much, if anything in terms of overall stability.
Honestly, it's pretty hard to go wrong with a used Johnson, Evinrude, or Mercury from 1980 onward.
Grouse
