Re: buying a used outboard
Depends on the amount of money Im spending, but as stated compression test, and run it. No test better than that. That is, on the water, not on muffs. Alot of motors run fine on muffs, but fail when under load on the water. Run it hard, make sure it doesnt over heat. Idle it for a while, ensuring it runs smooth and doesnt die. Do some cold starts, some warm starts. That will give you an idea about the reliability of the motor.
