Buying Boat Foam
tmyers921
Where is the cheapest place to buy the 2 part Boat Foam. Any Ideas?
92excel
Re: Buying Boat Foam
Normally calling around to local places around you is going to find you the cheapest since you wont have to ship it.
A lot of people say they went through US Composites, I have not personally
www.uscomposites.com
Mark42
What was the lowest price you found when you searched on Marine Foam and the like?
tmyers921
http://www.jgreer.com/
This place is the cheapest I found. I will look locally.
This boat redoing is confusing at times. I need to search these forums to see what the best Fiberglass Mat and cloth to use on my new deck. 2oz,3oz,????? Satin???? Wew!!!!!!! I'm covering it with a PVC material like carpet,,,But it's not carpet, don't hold water or rot. Shoot,,,,,I may just paint over the glass. *&&)%&%!!!!!
jcsercsa
Hay Tim , you had better check again , uscompositites has a 1.8 gal for 62 bucks, and shipping not going to kill you like it will from californa !!! john
Ps if you are in califorina then jgeer is the place to go but on this side of ther rockies i havent found a better place !! and the people there are great !! they helped me out quit a bit !!! John
j_martin
Cheapest I've found is a friend that builds insulated water tanks. Squirted my cavities full for free.
Seriously, one option is to find a small manufacturer that uses the stuff, and get him to squirt it in. With the machine mixed stuff you can get everything in place, drill some small (3/8 - 1/2 inch) holes into the cavities, squirt the foam in, and put your finish layer on.
