buying old diesel tank. Cleaning and filter question.
jgriner
Hey guys, Im thinking of buying a 50 gal diesel tank, with hand crank to store my 2cycle fuel for the outboard.
My questions is do i need to clean the diesel tank before putting in gas? Or just empty and fill?
Also the hand crank has a canister fuel filter, im sure its for diesel fuel, What type of filter should I use for 2cycle fuel? Im afraid that a filter might try to remove the 2cycle oil from the mix.
Thanks, john
Bob_VT
Re: buying old diesel tank. Cleaning and filter question.
As long as it in empty.......... just fill it. Even if there was a quart of diesel still dripping from the sides of the tank....... once mixed with that much pre-mix it will have no effect.
crb478
Clean it with a gallon of straight gas and then drain that, old diesel fuel can grow algea if untreated and you don't want that going into your boat motor
Georgesalmon
And,,,,a filter will not remove 2-cycly oil from the gas.
