Buying Pontoon
fod59
Need Help,i have been looking at a 2007 Odyssey 322c ,with a 115 Johnson 4 stoke,with 30 hours on ,excellent shape anybody know anything about the boat and motor,the other boat is a 2011 suntracker pb21 with a leftover optimax90 on it new,Im wanting a 22ft pontoon
The Rooster
Ensign
Re: Buying Pontoon
Welcome "fod59". I'm sure others will chime in shortly, but either barge is decent, depending on what you will be doing w/ it. More info would help though. How and where you will be boating, cruising, fishing, watersports ect. I don't believe Johnson made a 4-stroke. Usually just carb'ed 2-strokes. It's worth getting any engine professionally checked out IMO. Good luck !!!
Silvertip
Re: Buying Pontoon
Johnson offered a 115 HP 4-stroke which was a Suzuki with johnson badging. However that engine was only offered up through 2005 according to my sources.
5150abf
Re: Buying Pontoon
Both are decent boats, Odessey changed thier name to Southbay several years ago and the Tracker is a decent entry level boat, you should be happy with either one.
fod59
Re: Buying Pontoon
With and look at the suntracker pb21 ,did not like the size to small,going to look at the Odessey tomorrow.
