procraft180
- Joined
- Oct 20, 2005
- 24
I have a 2003 ProCraft 180 Combo with a Mercury 115 Four Stroke. Current prop is the stock prop, 13.25 x 19p,3b aluminum. I am turning 5600RPM at WOT/43MPH, full trim, full tank of gas, 2 people, with fising gear, running in a light chop. My engines recommended RPM range is 5000 - 6000. The outboard is mounted second hole from the top, looking at the top mounting holes. <br /><br />I am considering buying a Stainless prop this winter, and was wondering if anyone had any experiences with either the Stiletto Advantage or the Turbo 1. I am looking for a little better holeshot and mid-range punch, some more top speed would be nice, but not necessary. I sometimes pull a skier/tubes, but 90% of the time on water is spent running and fishing, so I would like to prop for that. Would also consider a 4 blade as well.<br /><br />With such a wide RPM operating range, should I stay closer to the 5600 number or go upwards to around 5800RPM's? This is my first Four Stroke outboard, so I still trying to learn the power characteristics of this engine.<br /><br />Thanks
