Re: Bypass VRO????----more----
acc<br /><br />Don't know about the suggestions part, but if you are going to disable it, here goes:<br />First, Remove the oil line from the tank to the engine and plug the nipple with a Vacuum cap and zip tie to hold it.(Auto Parts store).<br />Find the wiring harness that comes off the back of the VRO. The wires run to a round black rubber plug about 2" long & 3/4" in diameter. remove the spring-clip from it and un-plug it and tape it up. Next, find the 2 wires that run from the oil tank to the motor. Find the connectors and unplug them, pull the wires out of the cowl and remove the oil tank from the boat. Mix fuel in the tank 50:1 Mix and pump up the bulb to get it into the carbs, as they will have straight gas in them until the pre-mix reaches the carb. That's it.
