How would I take the VRO system totally out the mix? Can I get a fuel pump that would take it's place or do I need a fuel pump? It is on a 1989 Johnson 120hp.
if the fuel side of your vro is working, all you have to do is cut and plug the oil line, disconnect the wires on the pump, and oil tank. then premix your fuel.
if you want the pump completely gone, you will need 2 fuel pumps in series. cost of pumps is $200.00
