Re: c-map pc planer thoughts
The nav man uses c-map chips, you do not need to use the PC-Planner to load the chip into the Navman unit. <br /><br />What the PC-Planner does is allows you to use your chip at home on your PC for trip planning. The PC-Planner also allows you to transfer waypoints, routes, and trips from you Navman, to your PC and back. You can setup routes and waypoints on your PC and load them to the Navman.<br /><br />I use PC Planner to setup trips, before I make a new run, becareful as it is not 100% accurate. It is enough to get you where you are going, but can be off enough to put you out of the channel in some areas. (I boat in the Delaware river and the St Lawrence Seaway) <br /><br />Also if you are setting up your route, do not use the bouys on the chart for your waypoints, because if you do, it will be the one time the GPS and the chart match 100% you may not like the results.
