C55 idle speed up and down
Privateer
With new prop, fuel system repair and maintenance all caught up, motor has never run better. However, I still have a few questions. After rebuilding the carbs, the rpm fluctuates slightly (200 rpm) at idle. What can cause this? <br /><br />Also, would like to change out my 703 control with one of the flush mounted versions. I have the 10 pin harness. I know I will need the ignition switch with the choke and alarm, but how about my wiring? Am I good to go?
rodbolt
Re: C55 idle speed up and down
what year is your C55?<br />what do you have the idle speed set to?
Privateer
Its a 1994. The model # is C55TLRS. Idle speed is set to 1100 rpm. I will say that I am only using the Yamaha digital tach as my reference. Haven't bought a shop tach yet.
