cabelas oil
gshock
Has anyone used cabelas 2 cycle oil<br />good/ bad or indifferent.iam using<br />evinrude oil and not happy with the way<br />the motor runs.
NathanY
Re: cabelas oil
Why arent you happy with the Evinrude oil? Personally I run Quicksilver in my Evinrude, and it has done well with me. I know that I didnt really answer your question, but would like to know why youre not happy with current oil.
NathanY
Re: cabelas oil
Well Im probably gonna get my head bit off for this, but have you tried synthetic? It will get rid of both problems, especially while trolling.
Silvertip
Re: cabelas oil
I've run nothing but Cabelas semi-synthetic in my 95 Evinrude and have had zero problems.
Cricket Too
Re: cabelas oil
Never used Cabela's, but I usually use either West Marine brand or the Supertech from Wal-Mart and have no problem with either. My 200's smoke bad on any oil, including synthetic, but I've never had any trouble wth plugs fouling, I troll a lot and have never had plugs foul on any oil. You may want to try opening your gap up a little on your plugs if you troll a lot, to about .040, I 've heard it works better and that's what I usually do.
JB
Re: cabelas oil
Outboard Non-repair topic.
roscoe
Re: cabelas oil
My motor seems to smoke more with Pennzoil synthetic, than with Walmart's Supertech. Go figure that one out.
Major Woods
Re: cabelas oil
Sounds like a motor issue and not related to the oil.<br />Check thermostats and correct heat range of plug.
dajohnson53
Re: cabelas oil
Originally posted by Nate in Arkansas:<br /> Well Im probably gonna get my head bit off for this, but have you tried synthetic? It will get rid of both problems, especially while trolling.
Nate, to be fair, you should say "could" get rid of the smoking and fouling not "will". I for one (and there are others) have seen absolutely no difference running synthetic in spite of conventional wisdom to the contrary. No difference in smoking, certainly no difference in fouling (mainly because I never have fouling problems with my engine) Not trying to pick a fight, just pointing out to OP that it is not a fact, but rather a possibility. On the other hand, I do believe it's worth giving synth. a try for a gallon (of oil).
